Discussion topic: Mini box not connecting to sky Q box
This message was authored by: Malcyg57
Checked all internet and WiFi connection and even checked password to the WiFi but still not connecting
Re: Mini box not connecting to sky Q box
Hi @Malcyg57
Reboot the mini as above.
