Discussion topic: Mini box not connecting to sky Q box
Message posted on 06 May 2024 12:04 PM
Checked all internet and WiFi connection and even checked password to the WiFi but still not connecting
Message posted on 06 May 2024 12:26 PM
Re: Mini box not connecting to sky Q box
Hi @Malcyg57
Reboot the mini as above.
