Discussion topic: Internet not working on sky q box or mini, but Internet is working a ok with everything else??
This message was authored by: Kenmure38
Internet keeps dropping only from sky q box and mini box, happens every day, every two minutes, I've done all the necessary things, switch of at wall, reboot Internet back to box, every single time I do this, it just keeps buffering
Re: Internet not working on sky q box or mini, but Internet is working a ok with everything else??
Hi @Kenmure38
Try to get the main Q box connected first.
Reset your broadband router.
If you get the main Q box connected and the mini still has issues.
Avatar for Kenmure38
We have already done all of these and I have re done this again, as soon as its done it drops, only the the sky box and mini box, we also have a booster from yourselves, the rooter is in the same room as sky box,  this doesn't make sense, I have also had BT out to check my Internet connection and is running all good.they done checks on all cables and Internet speed.
