Discussion topic: Mini box failure
This message was authored by: Terri40
Mini box failure
The mini box upstairs will not turn on it says error m108 I've tried to reset it will not work at all
This message was authored by: bahadar+nagra
Re: Mini box failure
You you sure it is not MR108, the only way to get to bottom is contact customer services, or go through the normal rebooting the whole system
For the mr108 message, follow the Sky help article here;
https://www.sky.com/help/articles/problem-activating-sky-q-box
@Terri40 Have you tried rebooting your main Q box ie
then
rebooting your mini box
