Discussion topic: Mini box disconnecting each night at approx 2200
This message was authored by Abzy6900 This message was authored by: Abzy6900
I have a main sky q box and 2 minus plus a sky router. Main box connected via Ethernet cable to the router, bedroom mini connected via Ethernet to the router and one mini connected via wifi. Every night between 2200 and 2300 the bedroom mini disconnects itself with error code mr104. Very frustrating as each night if I turn the power off to the main sky a box for 5 seconds all works ok. Any clues please or it's all going in the bin.....
This message was authored by Daniel0210 This message was authored by: Daniel0210
Re: Mini box disconnecting each night at approx 2200
@Abzy6900
Rather than just turning the main box off for just 5 seconds have you tried rebooting all the boxes?
Try a reboot of the main Sky Q box first, then once that’s back up and running do the same with your mini boxes:
~ press the 🏠 button
I presume that's your frustration talking as that would be unwise. All Sky Q boxes are loaned to you and must be returned at the cancellation of a subscription, or in the case of the mini boxes cancellation of the Multiscreen subscription.
▪️I AM NOT A SKY EMPLOYEE (undercover or otherwise) ▪️
Abzy6900
I appreciate the reply but my solution works. I just want to stop it happening every night. I feel like Sky has turned into my dad and is telling me I can't watch tv in bed after a certain time. Why is it happening at the same time every night??????? There is clearly no connection problem of a quick on off would not work and the issue would still be there. I just don't get it......
This message was authored by PandJ2020 This message was authored by: PandJ2020
Such a disconnect could be caused by an external factor causing interference, such as a boiler or something else electrical possibly on a timer?
I am just another Sky customer and my views are my own
Abzy6900
Thanks for the reply but nothing on a timer, the bedroom mini is about only 2m away from the sky router so I'd be amazed if it's interference. It's really frustrating as having to turn the main box off interrupts recordings and spoils what I'm watching
...or thermostat - emf can be a problem.
