6
This discussion topic has been answered Discussion topic: Mini Box
This message was authored by: Mick+Evans
Mini Box
Sky minibox not connecting to main box correctly. States "waiting for TV listings" but they don't load.
Have rebooted several times over past couple of weeks but still not working.
Re: Mini Box
@Mick+Evans
Have you rebooted the main Sky Q box then done the same with the mini box?
Re: Mini Box
@Mick+Evans
Avatar for Mick+Evans
Re: Mini Box
Yes. Rebooted everything several times - same result.
Re: Mini Box
@Mick+Evans
Try rebooting your Broadband first, then the boxes.
Re: Mini Box
Just tried that but same result unfortunately.
"Waiting for TV Schedule "
Re: Mini Box
@Mick+Evans
If you search the forum using 'waiting for TV schedule' in the search box above you'll find that the advice to reboot normally rectifies the issue. Unless someone can suggest something different you may need to contact Sky.
Re: Mini Box
I've tried everything suggested now so have had to book an engineer.
Thanks for your help though.
