Discussion topic: Min Sky Q box not connecting and turning on
Message posted on 08 Aug 2023 12:11 PM
Router all ok, booster all ok, main box is working fine and only my mini box not connecting and turning on.
Message posted on 08 Aug 2023 12:14 PM
Re: Min Sky Q box not connecting and turning on
Hi @budster1
Have you tried pressing the Standby button (Amber led) on the front of the mini box.
If this turns the mini box on
Try completly resetting your mini Bluetooth remote.
Then make sure that you are pointing your remote at the Q box and press 1 & 3 together until the led flashes and follow onscreen instructions to re- pair.
Message posted on 08 Aug 2023 01:00 PM
Still not working, unable to connect and no signal is all I am getting
Error code keeps changing - now it is MR004
Message posted on 08 Aug 2023 01:10 PM
Hi @budster1
Reboot the mini as above.
If you are on Sky Broadband and the Router is nearer to the mini than the main box then you can try pressing WPS on the router instead of the main Q box
