Discussion topic: Connection to Qbox in the morning the tv needs to be tuned but not through the day
This message was authored by: Baw+Heid
When I switch on my smart tv and the Sky Q box in the morning I need to search for Sky to connect. Through the day the tv recognises SKY immediately I use my Sky box for all my programmes
Re: Connection to Qbox in the morning the tv needs to be tuned but not through the day
@Baw+Heid
Is the television trying to tune into digital terrestrial channels?
If so, that can usually be disabled using the television remote control.
@Baw+Heid what time in the morning is this at ?
Avatar for Baw+Heid
Level 2 icon
Usually about 8am
@Baw+Heid wrote:
Usually about 8am
Hi @Baw+Heid
Assume both your TV and Q box had been put into Standby (with Amber led) and not turned off at the mains.
Avatar for Baw+Heid
Level 2 icon
Yes both switched off. Same as through the day
When you say switched off @Baw+Heid
 Is this in standby or switched off at the mains?
Avatar for Baw+Heid
Level 2 icon
In stand by
Avatar for Baw+Heid
Level 2 icon
On standby
