Discussion topic: Memory card needs rebooting regularly Fault code is MR104
This message was authored by: Barry140652
Message on turning on TV that memory card is not inserted properly but it is. Fault code is MR104
Re: Memory card needs rebooting regularly Fault code is MR104
You mean Viewing card?
MR104 is a network connection error between the mini and Q, not related to a viewing card and usually shows up on the mini which doesn't have a viewing card anyway.
Or is it a TV specific error about some memory card facility it has?
Avatar for Barry140652
Looks like 2 issues. When Mini does not give TV upstairs it can be reset but shows MR104.
At same time downstairs TV says viewing card needs inserting even though it is in and up the right way!
This message was authored by: Invisiblename
Have you tried taking the card out, cleaning the chip with a soft cloth & re-inserting it?
I am just another Sky customer!
I will try, thank you.
Does anyone hava a UK phone number for Sky where you can talk to someone??!!
@Barry140652 You can contact Sky by phone by dialling 150 if Sky is your phone provider or by following the link below
https://www.sky.com/help/home
scroll down to need more help click on this and you will find a phone number. If you are in ROI please change the flag at the bottom right to the ROI flag
LG 49SJ 810 V UHD TV, Google Pixel 10 Pro XL mobile
This message was authored by: Mary+kennedy
Do I turn off the main sky q box? For how long?
Shouldn't matter
