4
This discussion topic has been answered Discussion topic: Sky Q box won’t connect to router
This message was authored by: Meggan_
An engineer came out on Friday, replaced the router gave us a booster and connected everything to the Sky Q box and mini box in the bedroom.
I go away for one evening and come back to watch tv... now the Sky Q box won't connect to the new router, or anything for that matter.
I have reset both the main Sky Q box and the new router. I've read through the answered forum and tried everything that it says and it won't help me.
I have tried to reconnect Q box to router using WPS as recommended but it won't pick it up, I have tried connecting to the router as "another broadband provider" but it keeps telling me the password is incorrect even though it's been quadruple checked.
I have been through the blue chat bot numerous times and nothing is helping. Imagine paying £90 a month for half of it not to work - getting ridiculous now.
Any ideas and further troubleshooting would be fab please.
Avatar for Meggan_
This message was authored by: Meggan_ Answer
Re: Sky Q box won’t connect to router
Appears the box was faulty. sky have issued a new box and everything is working as it should now!
Hi @Meggan_
Did you reset the new Q router before trying a Network reset onthe Q box?
Hold the Reset on the back of the router until the power light flashes green (about 10 seconds). Don't unplug or switch off your router while it resets. The power light will go green when it's done.
Highlight Status and then select Reset on the right hand side. Follow instructions to connect by WiFi to your router. Even if reset is not listed there is still an option to connect by WiFi to Sky router
On Sky Broadband you will be asked to press the WPS button on the Sky router. (Not on the Q box as the Network reset will start the main Q box WPS automatically). Make sure you press the WPS button on the Sky router and not the reset button.
Avatar for Meggan_
Yes I reset the router first; but also assumed this wasn't the issue as other devices are connected to the router with no issues.
i have since done a network reset on the router as described and still hitting the same issue as in my original post.
Avatar for Meggan_
This message was authored by: HossHey
Resetting the router worked for me!
Sky should put that in the set up instructions...
