6
This discussion topic has been answered Discussion topic: Longer wire
This message was authored by: Kieran+dillon
Longer wire
Hello
i need an engineer to come and make the wires form my satellite dish to my sky box longer
This message was authored by: bob1234 Answer
Re: Longer wire
@Kieran+dillonIf an extension lead is not suitable Sky may do it but will rewire from the dish to the box at the new location as they will not join cables. Their standard charge is about £65, you may be lucky sometimes they don't charge.
However if you want more control of where the wires go, Sky will only surface wire and go the quickest route, as the dish and cable belong to you an independent aerial installer will do what you want BUT get a quote first.
Re: Longer wire
@Kieran+dillon wrote:
Hello
Hi @Kieran+dillon
Satellite extension cables kits are readily available on Internet retail sites.
Just look for Satellite Extension cables.
Just bear in mind that you need two cables with the necessary two F connector fittings..
Some come as as a pair or as a twin (shotgun) cable and include the two female F connectors.   However some are single cables where you need two.
https://www.amazon.co.uk/YCAB03M-Satellite-Extension-Compression-Connectors-White/dp/B00627R8T6/ref=...
Re: Longer wire
Hello
If the extension leads aren't an option then call Sky to make an appointment - they may well charge though.
Re: Longer wire
Hi @Kieran+dillon   I'm afraid that you cannot request an engineer here as this is a community of customers.
Re: Longer wire
This message was authored by: Gary175
Re: Longer wire
Neeed engineer to reside dish to box aft
Re: Longer wire
Read the replies on this thread...
