13 Dec 2024 09:01 PM
My sky q mini box is connecting to the wrong WiFi network
13 Dec 2024 09:56 PM
Hi @Mf9
Sky Q minis can only connect to what you tell them when you reset their Network.
Reboot the mini as above.
