Discussion topic: Our Sony smart tv constantly loses internet connection
Message posted on 13 Dec 2024 08:03 PM
We have a Sony smart tv (Google ) with Sky package. For some reason we keep getting an error message 'you don't seem to have an internet connection', also sometimes the sky remote stops working. Done all the turning off and on, resetting password, resetting remote but still keeps happening!
we have a strong internet connection and don't have issues with other devices, any ideas what this could be?!
Message posted on 13 Dec 2024 08:12 PM
Re: Our Sony smart tv constantly loses internet connection
Hi @Dunx
Assume you are referring to the Internet connection of your Q box. This has nothing to do with the Internet connection to your smart TV.
Connection of internet to Q box and TV is totally independent
To connect your Q box
Message posted on 13 Dec 2024 08:25 PM
Thanks, will that a try!
