This discussion topic has been answered Discussion topic: Longer wire
Message posted on 27 Mar 2023 10:06 AM
Hello
i need an engineer to come and make the wires form my satellite dish to my sky box longer
Message posted on 27 Mar 2023 11:59 AM
@Kieran+dillonIf an extension lead is not suitable Sky may do it but will rewire from the dish to the box at the new location as they will not join cables. Their standard charge is about £65, you may be lucky sometimes they don't charge.
However if you want more control of where the wires go, Sky will only surface wire and go the quickest route, as the dish and cable belong to you an independent aerial installer will do what you want BUT get a quote first.
Message posted on 27 Mar 2023 10:13 AM - last edited: 27 Mar 2023 10:14 AM
Re: Longer wire
@Kieran+dillon wrote:
Hello
Satellite extension cables kits are readily available on Internet retail sites.
Just look for Satellite Extension cables.
Just bear in mind that you need two cables with the necessary two F connector fittings..
Some come as as a pair or as a twin (shotgun) cable and include the two female F connectors. However some are single cables where you need two.
Message posted on 27 Mar 2023 10:14 AM
Re: Longer wire
@Kieran+dillon wrote:Hello
If the extension leads aren't an option then call Sky to make an appointment - they may well charge though.
Message posted on 27 Mar 2023 11:38 AM
Re: Longer wire
Hi @Kieran+dillon I'm afraid that you cannot request an engineer here as this is a community of customers.
Message posted on 13 Dec 2024 09:04 PM
Re: Longer wire
Neeed engineer to reside dish to box aft
Message posted on 13 Dec 2024 09:11 PM
Re: Longer wire
@Gary175 wrote:Neeed engineer to reside dish to box aft
Read the replies on this thread...
