This discussion topic has been answered Discussion topic: Location check failure
Message posted on 17 Sep 2023 11:27 AM
When trying to download I keep receiving a location check failure and everything fails. Any idea how to fix please
Message posted on 17 Sep 2023 11:35 AM
Who is your broadband provider?
Message posted on 17 Sep 2023 11:37 AM
Re: Location check failure
Community Fibre
Message posted on 17 Sep 2023 11:44 AM
Others with Community fibre on here have reported this issue.
Might be worth having a look there.
https://helpforum.sky.com/t5/Sky-Q/Failure-of-download-location-check-failed/td-p/4360786
The last post suggest going into the link says settings and refreshing your ip address.
Others have called them and they are aware of some problems.
The failure does come from an invalid ip address, that Sky Q is not able to resolve correctly or assumes it's not a UK address, even though it maybe.
Message posted on 17 Sep 2023 11:52 AM
@lettice Thank you! I am now in touch with CF so let's see if they can fix it
