Discussion topic: Linking mini box to sky Q box. Gone through instructions however still not connecting.
This message was authored by: Karimo
The mini box not connecting to Sky Q box. Extremely frustrating as I have done everything instructed to do. Can someone please help.
Re: Linking mini box to sky Q box. Gone through instructions however still not connecting.
Hi @Karimo
Have you carefully followed the instructions below.
Reboot the mini as above.
If you are on Sky Broadband and the Router is nearer to the mini than the main box then you can try pressing WPS on the router instead of the main Q box.
Make sure you press the WPS button on the Sky router and not the reset button.
