Discussion topic: Hi I have been on holiday and whilst I was away there was a power cut. I have now lost all of my rec
This message was authored by rsdoidge1 This message was authored by: rsdoidge1
Hi I have been on holiday and whilst I was away there was a power cut. I have now lost all of my recordings on my SkyQ box. I have tried rebooting twice to no avail. Can you help?
Re: Hi I have been on holiday and whilst I was away there was a power cut. I have now lost all of my
Hi @rsdoidge1
Assume you have checked if anything is in the  Recordings - Manage  - Deleted section.
Normally a power cut will not wipe recordings.
You could try a reset Settings  in the Q box hidden menu but not sure this will help if you have tried rebooting.
