6
This discussion topic has been answered Discussion topic: Issues with sky
This message was authored by: Laura1984222
Issues with sky
We have skyQ for around a year, since Tuesday 20th June we have had alot of problems connecting to any social media such as Snapchat, Facebook and alot of gaming apps such as steam and discord.
While we are connected to the WiFi, we can not get any connection to any of the above apps, but while we are on mobile data, it works fine.
Would appriciate any help as we feel like we are paying for very little
This message was authored by: Laing1 Answer
Re: Issues with sky
@Laura1984222 If you have Sky as your broadband provider then you may have to change some of the age settings in  broadband shield.
You can access the broadband shield settings through the my sky app or by logging into https://www.sky.com/ then choosing broadband
LG 49SJ 810 V UHD TV
Google Pixel 10 Pro XL mobile
This message was authored by: SlenderRobert
Re: Issues with sky
@Laura1984222
You say you have Sky Q but do you have Sky Broadband too? Have you tried rebooting your router? Turn it off at the wall for a minute then back on and wait for all the lights to turn green.
Re: Issues with sky
Avatar for Laura1984222
Re: Issues with sky
Ah yes, we do also have sky broadband, apologies.
Turned everything off for 30 seconds, waited for lights and still no luck. Annoying part is that it will all work fine on mobile data, but WiFi will not connect to any social media
Re: Issues with sky
@Laura1984222 look at the post I posted just above yours they have crossed 😀 and you may not have seen mine
Re: Issues with sky
So somehow, without touching the sky broadband shield settings, they've been classed as not family friendly, turned it off and it has seemed to work for now, will leave it and see if anything changes, but thank you for your help @Laing1
Re: Issues with sky
@Laura1984222 you are more than welcome 😁
