Discussion topic: Just recieved replacement sky Q box but no appear how do we get them back. pps appesr
This message was authored by: imbjp21
My replacement sky Q box will mot display apps..any ideas how to get them back?
Re: Just recieved replacement sky Q box but no appear how do we get them back. pps appesr
@imbjp21 you could try refreshing the apps in the engineers menu
To enter the engineers menu do the follow
press the home button then scroll down to setting and hi-light
do not press select/enter but press 001 then select this takes you into the engineers menu
scroll down to apps > refresh
LG 49SJ 810 V UHD TV
Google Pixel 10 Pro XL mobile
