Discussion topic: Issues with Sky Q Mini box
Message posted on 29 Feb 2024 09:41 AM
Hi, I have had my sky mini box for years. I woke this morning to find that it is telling me to "Please check your subscription entitles you to..." My main box is fine and is working perfectly. I cannot access any channels or recordings only the apps. I have reset my box multiple times, unplugged it from the sockets everything to no avail. I literally cannot find a way to get a hold of customer serviced
Message posted on 29 Feb 2024 09:55 AM - last edited: 29 Feb 2024 09:56 AM
Re: Issues with Sky Q Mini box
Hi @Ayk88
Reboot the mini as above.
Message posted on 29 Feb 2024 10:50 AM
@oldfella I have tried all of the suggestions you have given me however still no success.
Message posted on 29 Feb 2024 10:59 AM
Hi @Ayk88
Try a Reset Settings in the main Q box hidden menu.
When the main Q box is completely back up and running reboot the mini again
Message posted on 29 Feb 2024 12:56 PM
Hi @oldfella thank you again for all of the steps. Im still not having any luck, I'm afraid.
Message posted on 29 Feb 2024 01:02 PM
Hi @Ayk88
In your Main Q box.
Home menu - Settings - Status.
Does Watch on Sky Q Mini Box have a tick?
Even if it does Select it and then Select Reactivate on the right hand side.
The other thing to try is to refresh your Viewing card.
Home - Settings - System info.
Highlight Viewing card number and then select Setup on the right hand side.
Then select Use this option to trigger a callback
No call is actually made but the Viewing card should be refreshed.
Message posted on 29 Feb 2024 01:19 PM
Hi @oldfella Im still not having any luck I have just tried reactivating and refreshing the viewing card. Im not sure what else I can do
Message posted on 29 Feb 2024 01:23 PM
Hi @Ayk88
I have escalated your post to Sky.
You may receive an email or a private message inviting you to have a private conversation on the Community with a Sky Expert.
Look out for a chat bubble at the bottom of your screen inviting you to a chat
The link below explains how the escalation process works
Message posted on 29 Feb 2024 01:51 PM
Thanks for escalating this. We’ve sent @Ayk88 an invite to chat.
Lisa - Sky Tech Team Expert
