Discussion topic: Cant view ch 164 Blaze on skyq box or my secondary box.
This message was authored by: Alan109
Getting 4 horizontal flickering green bands and can hear audio. No message about loss of signal. Trired turning on and off and checked connections are finger tight?
Re: Cant view ch 164 Blaze on skyq box or my secondary box.
Seeing the same here @Alan109
It's not your box it's the Channel
Avatar for Alan109
Thanks, is it a case of hoping they notice and correct their problem?
I never watch the channel @Alan109
So don't know if this is a regular issue!
If the problem doesn't go away you could try contacting Sky Viewer Relations.
viewerR@sky.uk
@Alan109
There's an email address under the Contact Us link at https://www.blaze.tv/
