Discussion topic: Issues with ITV
This message was authored by: me+in+gloucester
Issues with ITV
Suddenly having issues with watching ITV channels. Initially said no satellite signal being received on all channels. Down powered and turned back on. Now all itv channels pixelating. All other channels fine. Signal strength and quality fine. Any ideas guys?
Re: Issues with ITV
@me+in+gloucester
It does sound like your dish might be slightly out of alignment. Whenever a “no satellite signal” message is displayed firstly check that the connections from the Sky dish going into the back of your Sky Q box are still finger tight. Also check out the troubleshooting on this link
It may then give you the opportunity to arrange an engineer to check the alignment of your dish.
It’s not necessarily something that will be visible to the naked eye and could only affect one or two channels. If you’re on a communal dish you may initially need to liaise with your landlord or building management company.
▪️I AM NOT A SKY EMPLOYEE (undercover or otherwise) ▪️
Avatar for me+in+gloucester
Re: Issues with ITV
I'm not sure it is as the signal strength and quality is decent. It's the same levels when ITV goes all pixelated. It often corrects itself and when it does it's ok for days.  Very strange.
Re: Issues with ITV
hi @me+in+gloucester
The signal quality info on SKY Q is slightly misleading - It does not show the strength & quality of the channel you are watching but a fixed transponder set in an engineer's menu
This message was authored by: Psych67
Re: Issues with ITV
I'm having serious signal problems when I watch ITV using my sky + box. Pixelated picture-Spoke to Sky today I'm not eligible for a SkyQ box because I live in a block of flats. This problem has got to be resolved between ITV and Sky; it's the most ridiculous thing I've ever heard of.
Re: Issues with ITV
hi @Psych67
This is more likely a problem with your Communal distribution system and needs to be addressed by whoever looks after your system
Also many Communal systems can be upgraded to work with SKY Q but again it is down to the Communal system being able to be adapted
Re: Issues with ITV
@nigea99  Thank you, but I was told by Sky that the Sky + box is no longer compatible with ITV channels and that other people have also reported the same issue. The best solution they said is to get a Sky Q box but as I'm not eligible they suggested I get a Sky Streaming Puck. Have never heard of this before and am inclined to change provider. I find this all too tedious.
Re: Issues with ITV
hi @Psych67
If you only have SKY + (SD only)  box  rather than a SKY HD box then you will are likely to have lost BBC & ITV channels and will soon loose more channels as the old SD only boxes cannot decode HD channels and the SKY SD chanels that are changing transmission modes in the near future
If you have a SKY HD box then these changes should not affect you and you have been mis-informed
SKY Stream works via the internet and you need a good stable connection for that (which you may have)
Re: Issues with ITV
@nigea99 Thank you for this-I have a Sky + HD box...apologies if I lead you to think otherwise.
What do you mean by: "if you have a SKY HD box then these changes should not affect you and you have been mis-informed"?
Re: Issues with ITV
@nigea99 Just to add: I do have a good stable wifi connection, so would you suggest I go down the streaming puck route? I've never heard of this before.
Re: Issues with ITV
@nigea99 Thank you for your help with this-I need to go to sleep-very early wake-up call tomorrow, but will check messages tomorrow.
Many thanks!
Re: Issues with ITV
Simply the response you mention from SKY
".... but I was told by Sky that the Sky + box is no longer compatible with ITV channels and that other people have also reported the same issue......"
is not applicable to you with a SKY +HD box - SKY HD boxes are quite capable of working with the ITV channels (hence my initial reply about your communal system)
Re: Issues with ITV
SKY Stream is quite a different product  - many people like it but other people that have been used to Satellite boxes (SKY HD & SKY Q) are not so keen
I can't really advise other than suggest if you think you might switch that you do some research
BTW SKY Q also has quite a different user Interface to SKY HD that many don't like (there are other diffferences but if you can;t get it I won't link to my notes on that)
Re: Issues with ITV
@nigea99 Thank you for both replies yesterday! Much appreciated. I'll wait to see if somebody from Sky replies to my post and take things from there. Thank you again for your input-it is much appreciated. 🙏
Re: Issues with ITV
Sky won't respond to your post on here. There is no issue receiving ITV channels on a Sky+HD box.
Sky Community Forum SuperUser
Former Sky+HD Beta Tester
