Discussion topic: Issue changing channels
This message was authored by: Vicky703
Hi, has anyone else experienced issues changing channels from Channel 4 using grey the circle then arrow buttons on the sky remote?
Whenever we try we are being defaulted onto the C4 app - which we've never even registered on?
does that make sense ?
Re: Issue changing channels
Hi @Vicky703   I'm afraid not, no idea of what you are trying to do.
If you hit the 'grey circle' (select) when the 'start programme from the beginning' is displayed then it fires up the relevant streaming app.
You can wait for the banner to disappear or dismiss it with 'back'.  Or don't hit the select button at all when using the up and down arrows to preview channels.
This message was authored by: Peter0208
Problems changing channels
When I scroll to a channel, when I get to the desired channel, it downloads the programe from the start?? I have subscribed to SKY Q since day one and it is only today this has started to happen, just turned to watch the FOOD NETWORK and unless I tap in the channel number it takes me to the channel 4 app, If i use the up and down channel buttons, this doesn't happen. Any one got any ideas, I've done a software update and a hard reset of my box but it is still happening.
Avatar for Vicky703
Re: Problems changing channels
@Peter0208  yes thats exactly what we are getting (you explained it better than me !)  it's so frustrating!
This message was authored by: JaneP02
Hi Both
Yes this is exactly the same problem we have got - its on both the main box and the mini and has only started in the last 24 hours. We have had Q boxes since they first came out and again, this hasnt been an issue before - mind you our Q box does have some quirks and issues that we have to live with (it records progarmmes we have never watched before, misses out on episodes on series link and other odd behaviour) . But with this problem both boxes have been reset etc and the changing channel issue is still there.
Any suggestions??
This message was authored by: mrbazzabee
Same problem here, only started doing it in the last week from Channel 4 only.
Always been able to press 'circle' followed by up and down to search channels, followed by circle to select. Doing this on Channel 4, shows other channel previews all as 'watch from the start' instead of the normal overview.
Very strange change, and pretty annoying.
I have alerted Sky to this in a closed part of the forum I am also seeing this.
It only happens for me if I am on a ch4 owned channel and I use the mini guide
I've also found rather than pressing the select button (middle button) if you press the info button to bring up the mini guide then scroll through the mini guide and press select to switch to a channel this works and switches you to the channel rather than bringing up the ch4 app
LG 49SJ 810 V UHD TV
Google Pixel 10 Pro XL mobile
This message was authored by: Sharon+Marshall22
Yep same thing happening to me.  Started doing it yesterday.  Very irritating.
This message was authored by: SharkyMoo
Having exactly the same issue! If I go to select ITV for example it will open the C4 app?? It's extremely irritating, also done the software update and reset. Its like everything is mapped to the C4 app
This message was authored by: Hazardousbenji
Same issue, my wife has just shown me, she said was doing it on mini box last night and thought she was doing something wrong, just showed me on the main sky q box, it happens when the 'watch from start' option is there and loads up the channel 4 app instead of going to the selected channel.
I've tried with info button and doesn't help.  The issue seems to be when the 'watch from start' option is shown on the preview in the mini guide then this is when it directs to c4 app when select is pressed.
If it's some kind of update "to improve customer experience" it's doing the opposite! My hubby is preprogrammed to change channels this way so it's a MAJOR inconvenience of course.
This message was authored by: Redkickers
Yip same here just seen it tonight that it was doing it only from Ch4 if you then scroll to any other Chanel it's play from start and if you try and change it takes you to ch4 app and regardless of multiple reboots still doing it has anyone had anything from sky on this clearly a fault across the board with sky Q
This message was authored by: Chloe-W22
Posted by a Sky employee Posted by a Sky employee
Hi all,
Thanks for flagging this, I'll reach out to our support teams and let them know! Would you be able to tell me the software version you're on as this might be a common factor? 😊
Settings > System Info
Chloe-W22
Sky Community Manager
Have a story you want to share with us? Send your Thanks to Sky here
