4
This discussion topic has been answered Discussion topic: ITV problems
This message was authored by: ColinG54
ITV problems
ITV programmes won't play from start when selected . All other channels work.
Predictable message displayed saying technical fault . Any ideas ?
Avatar for ColinG54
This message was authored by: ColinG54 Answer
Re: ITV problems
Thank you .
I've tried this twice but no luck .
is it a problem at ITV.
I never get an answer if i message them.
And the one programme i need this for in particular doesn't ever end up on ITV x for three days !!!
This message was authored by: LJB-C
Re: ITV problems
Posted by a Sky employee
Hi @ColinG54, I’ve escalated your post to our Community Messaging team who will invite you to a private chat shortly and help you with this.
Re: ITV problems
Hi @ColinG54 Try rebooting your router by removing the power cable for 30 sec then reconnect to reboot, then reboot your main SKYQ box by turning the power off at the socket for 30 sec then turn back on?
Avatar for ColinG54
Re: ITV problems
Will do thanks . It's Sky Glass not Sky Q.
Avatar for ColinG54
Re: ITV problems
Thank you .
