8
This discussion topic has been answered Discussion topic: ITV HD not available on Mini Box
This message was authored by: Beth.MacL
I noticed this morning that ITV HD was not working on the mini box - the message stating there is a technical fault with the channel. All other channels working. I spent an hour on the phone to a very helpful Sky technician who tried everything but could not fix the issue. She then received a reply to her message to colleagues stating that ITV have just changed things and it is a known fault that ITV HD is no longer available. I hope Sky deal with this soon and make it available.
Avatar for Beth.MacL
Level 2 icon
This message was authored by: Beth.MacL Answer
Re: ITV HD not available on Mini Box
I have just checked the mini box and ITV HD is back working. No idea what that was all about, but thanks to everyone for their comments.
Hi @Beth.MacL
Reboot the mini as above.
Which region are you in? Have you rebooted the mini box? ITV are making some changes at the moment but it shouldn't result in any HD channels being unavailable.
Level 2 icon
I am in the West. The agent told me to check over the next few days just in case it springs back in to action! I was on for an hour and we did everything possible - resetting boxes, updating software etc.
Level 2 icon
The Sky agent I spoke to for an hour tried all this. We rebooted both boxes several times, updated software on both boxes, reset the Sky wifi booster and nothing resolved it. As stated in my original post, a colleague messaged her to say it is a known fault and presumably it will need an upgrade to the mini box hardware.
Doubt it, certainly not to the hardware and problably not to the firmware. Probably just a frequency change or something so a change to the tv guide data.
There's a very small chance that the problem is at Sky's end and they haven't updated the EPG to link to the new frequency. Problems like that are usually fixed extremely quickly and there's no reason this would only affect a mini box, so it seems very unlikely. We'd need someone else in the ITV West regon to confirm whether or not ITV HD is working for them.
This message was authored by: Ninya
Hi. Our Sky q Mini is also not able to display ITV 1 HD at the moment.
Tried resetting everything. All other channels are fine.
Location NorthWest
Level 2 icon
