Discussion topic: I need a replacement SkyQ remote, the original has dropped onto a hard floor and the IR is broken
Message posted on 04 Mar 2023 07:48 AM
Please can you send me a new SkyQ remote as I cannot use Sky at the moment.
Message posted on 04 Mar 2023 08:00 AM
Re: I need a replacement SkyQ remote, the original has dropped onto a hard floor and the IR is broke
@Ravensoak
This is a customer helps customer based forum. I’m afraid you aren’t addressing Sky Customer Services on here.
If your Sky Q remote is definitely broken/faulty if you follow this link it should allow you to do some troubleshooting and then send you to a form to request a replacement (this is not available for ROI customers).
https://www.sky.com/help/articles/lost-stolen-damaged-sky-q-equipment#get-in-touch
Otherwise you can purchase a new one from a lot of retailers / main supermarkets.
Message posted on 04 Mar 2023 08:11 AM
Thanks, reading some other posts it advised to post here. I will try the link and see if I can get help that way. Thanks again.
