Discussion topic: I'm at mam's home, her sky q box is saying no digital TV signal available
This message was authored by: GDS5
I'm currently at mam's home, the sky q box is saying no digital TV signal available.
Re: I'm at mam's home, her sky q box is saying no digital TV signal available
@GDS5
A message displaying ”no signal” tends to be generated from her TV and normally means her TV’s not seeing the Sky box on the relevant HDMI input.
If a message displays “no satellite signal” it relates to her Sky Q box, so firstly check that the connections from the Sky dish going into the back of her Sky Q box are still finger tight. Otherwise it’s likely to be a dish alignment issue so check the troubleshooting in this link
It may then give her the opportunity to arrange an engineer to check the alignment of her dish. If it doesn’t she will need to contact Sky to book an engineer appointment.
If she is connected to a communal dish she needs to liaise with her building management company / landlord who will have their approved engineers to contact.
Remember, a misalignment is not necessarily something that will be visible to the naked eye and could only affect one or two channels.
Hi @GDS5
Are you sure that the Television is switched to the correct HDMI input for the Q box?
Looks like she is trying to access the Terrestrial TV tuner service without a Terrestrial aerial.
Avatar for GDS5
Level 0 icon
Her sky q was installed by engineer a year ago, with no problems until today.
Picture is just pixelating and freezing. Remote won't change channel or anything.
Hi @GDS5
So I assume you have checked that the Television is on the correct HDMI input?
Have you tried rebooting your Q box?
@GDS5 that message definately sounds as though it is from the TV and not the Sky box i'd do as @oldfella has suggested
LG 49SJ 810 V UHD TV
Google Pixel 10 Pro XL mobile
So is it saying "no digital TV signal available" (which as above is a freeview error about not having an aeriel attached or tuned) or is it freezing and pixellating (which could be one of several things)?
