10
This discussion topic has been answered Discussion topic: I have Sky Sports but it says I need to upgrade for Sky sports plus
This message was authored by: Chris308
I keep getting a message saying I need to upgrade to view a game in Sky Sports plus but I thought if you have Sky Sports it is free
Re: I have Sky Sports but it says I need to upgrade for Sky sports plus
Only if you have the Full Sky Sports Pack @Chris308
@Chris308  Do you have a full sky sports subscription?
single channel subscriptions don't qualify for access
Avatar for Chris308
Do Sky Sports Premier League, Football and HD isn't the total package?
@Chris308
You need the full Sky sports package.
No that's not the Sky Sports Full pack @Chris308
Avatar for Chris308
Ok thanks
Hi @Chris308   To give it its proper name "Sky Sports Complete including Sky Sports+".
Avatar for Chris308
So it's probably best me giving them a ring because I'm not going to upgrade to full Sky Sports package as I already have some components of it and need them taking out
Hi @Chris308
If you speak to Sky directly you may be able to do a deal.  I'm sure that you will find the Complete Sports pack with a new 24 month contract will not be much more expensive then the individual packs you have.  The Complete Sports pack will replace the individual packs
Avatar for Chris308
Yes you're probably right. Thanks for your help
