Discussion topic: Accidently hit a button on sky q remote now only have a black screen with sound remote doesnt work h
This message was authored by: Lisa19731
I have hit button now only have a black screen with sound sky q remote won't work either any idea how I fix please?
Re: Accidently hit a button on sky q remote now only have a black screen with sound remote doesnt wo
Hi @Lisa19731
First reboot your Q box.
if you have to press the Standby button (Amber led) on the front of the Q box to bring it on then:
Avatar for Lisa19731
Level 0 icon
Hi is this the same process if my main tv is working fine but upstairs tv Is the one with the issue?
Thank you
Thank you
Yes @Lisa19731
Just read mini box and mini remote
Hi @Lisa19731   My guess is you have hit the "input" button (top right). Just keep hitting it until the picture returns (correct HDMI input on the TV).
