Discussion topic: I can't turn on the sky completely because only the yellow light is on and it doesn't show anything
This message was authored by: Vilmaiv
Re: I can't turn on the sky completely because only the yellow light is on and it doesn't show anyth
Hi @Vilmaiv
Try pressing the Standby button (Amber led) on the front right of the Q box.
If this brings the box on then your remote probably needs resetting or new batteries.
If the batteries are OK Try completly resetting your Bluetooth remote.
Then make sure that you are pointing your remote at the Q box and press 1 & 3 together until the led flashes and follow onscreen instructions to re- pair.
Avatar for Vilmaiv
Nothing changes, no light or LED flashes up
Nothing changes, no light or LED fleshes up
Re: Nothing changes, no light or LED flashes up
Hi @Vilmaiv
Try rebooting the Q box.
Avatar for Vilmaiv
Avatar for Vilmaiv
I thought it would start working because there was both a blue and a red light, but later it turned
Not working
I thought it would start working because there was both a blue and a red light, but later it turned yellow, which did not show up on the remote control even after pressing it. Now the green light is on, but I can't turn on the TV
Re: I thought it would start working because there was both a blue and a red light, but later it tur
@Vilmaiv wrote:
Not working
Hi @Vilmaiv
So the Q box is now on with green led?
Why can't you turn on the TV?
Avatar for Vilmaiv
Start to work 🤩 thank you
Done thank you
This message was authored by: Matt136
Hi, I'm having the same problem. How did you fix it? Thanks
@Matt136
Have you tried the advice from @oldfella or rebooted your box(es) as already suggested?
Try a reboot of the main Sky Q box, then once that’s back up and running do the same with any mini boxes if necessary-
~ press the 🏠 button
stilll only an amber light and tried to reboot. Nothing showing on screen
I only have the solid amber light. There is nothing coming up on my TV and have also tried to reboot it
This message was authored by: Gamma56
SKY Q Full system restarted but the remote still not responding ni led lights, tried 7&9, 1&3, 1&7 no joy.
Gamma56
the sky box needs to be on I think (press the button manually) before holding down 7&9 etc will work.
