2
This discussion topic has been answered Discussion topic: I am unable to record or download on my Sky Q box
This message was authored by: PaulKibby
I am unable to record or download on my Sky Q box. I have turned off at the switch and turned back on but no change. I have checked my internet connection and all fine
This message was authored by: Doc5907 Answer
Re: I am unable to record or download on my Sky Q box
@PaulKibby
Try a Reset Settings in the hidden menu.
Scroll down to Reset
After the Reset you may have to re pair your Bluetooth remote If you use one.
Sky Q 1TB UHD
LG TV
Sky Mobile
@PaulKibby
Sky Q 1TB UHD
LG TV
Sky Mobile
@PaulKibby is this on all channels or only one ?
LG 49SJ 810 V UHD TV
Google Pixel 10 Pro XL mobile
Answered - Go to Answer
