Discussion topic: How many ways to reboot SKY Q Box?
This message was authored by: menezes02
Hello everyone,
I recently learned that I can reboot the SKY Q Box by:
Press Home on your Sky Q remote and select Settings, then Setup.
Select Preferences, followed by Standby mode and select the setting you want.
Is there any different way of doing it?
Thank you
Re: How many ways to reboot SKY Q Box?
@menezes02
The main reboot method is -
~ press the 🏠 button
Allow 5-10 minutes before things hopefully revert back to normal.
Avatar for menezes02
@Daniel0210
Thanks for the help! That method works great when I have physical access to the box. However, I was looking for a way to reboot it remotely using the Sky Q remote, as I sometimes don’t have direct access to the device. Do you know if there’s another way to do it through the remote only?
Appreciate your input! 👍
@menezes02 wrote:
@Daniel0210
Change the max number of recorded channels from 5 to 6 (or vice versa) - the box reboots...
Thank you for your time, that's the only way I know how to do it and I am wondering if there is any more. Cheers!
Eh? Isn't that two ways now?
@Chodley I made a mistake on my post that actually the way I learned how to do it so my apologies. Apart from this do you know any more ways of doing it? Appreciate your time and help, cheers! 🤝
No.
...get a smartplug and control it remotely.
@PandJ2020 I think that's what I gonna do! Appreciate your time and support, cheers! 🤝
