Discussion topic: How many ways to reboot SKY Q Box?
Message posted on 07 Mar 2025 10:15 AM
Hello everyone,
I recently learned that I can reboot the SKY Q Box by:
Press Home on your Sky Q remote and select Settings, then Setup.
Select Preferences, followed by Standby mode and select the setting you want.
Is there any different way of doing it?
Thank you
Message posted on 07 Mar 2025 10:17 AM
Re: How many ways to reboot SKY Q Box?
@menezes02
The main reboot method is -
~ press the 🏠 button
Allow 5-10 minutes before things hopefully revert back to normal.
Message posted on 07 Mar 2025 10:21 AM
@Daniel0210
Thanks for the help! That method works great when I have physical access to the box. However, I was looking for a way to reboot it remotely using the Sky Q remote, as I sometimes don’t have direct access to the device. Do you know if there’s another way to do it through the remote only?
Appreciate your input! 👍
Message posted on 07 Mar 2025 10:53 AM
@menezes02 wrote:@Daniel0210
Change the max number of recorded channels from 5 to 6 (or vice versa) - the box reboots...
Message posted on 07 Mar 2025 10:59 AM
Thank you for your time, that's the only way I know how to do it and I am wondering if there is any more. Cheers!
Message posted on 07 Mar 2025 11:25 AM
Eh? Isn't that two ways now?
Message posted on 07 Mar 2025 11:29 AM
@Chodley I made a mistake on my post that actually the way I learned how to do it so my apologies. Apart from this do you know any more ways of doing it? Appreciate your time and help, cheers! 🤝
Message posted on 07 Mar 2025 11:57 AM
@menezes02 wrote:Apart from this do you know any more ways of doing it?
No.
...get a smartplug and control it remotely.
Message posted on 07 Mar 2025 01:49 PM
@PandJ2020 I think that's what I gonna do! Appreciate your time and support, cheers! 🤝
