This discussion topic has been answered Discussion topic: How do i find out my pin number
Message posted on 12 Apr 2023 04:06 PM
Why do I need a pin number for some channels and were do I find it
Message posted on 12 Apr 2023 04:43 PM - last edited: 12 Apr 2023 04:48 PM
Hi @Freir
Unless you have changed it, your pin number is usually the last 4 digits of your viewing card number.
You can find your viewing card number in Home - Settings - System info.
See following link to reset your pin
Hi @Freir
Message posted on 02 Jun 2023 08:59 PM
Re: How do i find out my pin number
Hi how do I get my pin number
Message posted on 02 Jun 2023 09:04 PM
I've forgotten my pin number
Please see @oldfella 's response above your post
Message posted on 11 Sep 2023 04:10 PM
When setting up a account with sky the pin is ushaly set up at same time and should be the last 4 digits of your phone number unless changed since
Message posted on 11 Sep 2023 04:13 PM
@Anonymous wrote:When setting up a account with sky the pin is ushaly set up at same time and should be the last 4 digits of your phone number unless changed since
You do realise that you are responding to a 3 month old post?
Message posted on 11 Sep 2023 04:17 PM
Yes but likely someone else will come through with same problem and find my comment helpful I been trying to fined mine and reading comments with no luck until found out and remembered setting it up so hopefully helpful to someone else in future
Message posted on 11 Sep 2023 04:18 PM
@Anonymous wrote:Yes but likely someone else will come through with same problem and find my comment helpful I been trying to fined mine and reading comments with no luck until found out and remembered setting it up so hopefully helpful to someone else in future
OK, but the default PIN number is the last 4 digit on your viewing card, not your phone number.
Message posted on 11 Sep 2023 04:26 PM
That's good for those who have cards I have the sky puck which don't have a card and is pin is last 4 digits of your phone number so I guess different if you have a viewing card
Message posted on 11 Sep 2023 04:31 PM
@Anonymous the difference is you have Sky Stream which has no viewing card, this is the forum for Sky Q and Sky Q boxes do have a viewing card
Message posted on 11 Sep 2023 04:33 PM
@Anonymous
You've posted on a thread in the Sky Q board so it will be the viewing card solution as described by @Invisiblename and therefore your puck isn't relevant.
Message posted on 11 Sep 2023 08:36 PM
@Anonymous wrote:That's good for those who have cards I have the sky puck which don't have a card and is pin is last 4 digits of your phone number so I guess different if you have a viewing card
As you've posted in the wrong forum, all you're doing is potentially confusing Sky Q users
Message posted on 09 Oct 2023 08:00 PM
Just started to open my new sky tv end is asking me for pin to enter how I can get the pin to start my tv
Message posted on 09 Oct 2023 08:06 PM
Do you have a SKY Glass TV or a SKY Q box ?
