46
This discussion topic has been answered Discussion topic: How do i find out my pin number
This message was authored by: Freir
Why do I need a pin number for some channels and were do I find it
Re: How do i find out my pin number
Hi @Freir
Unless you have changed it,  your pin number is usually the last 4 digits of your viewing card number.
You can find your viewing card number in Home - Settings - System info.
See following link to reset your pin
https://www.sky.com/help/articles/your-pin-sky-q-unblock
Hi @Freir
This message was authored by: Mariomark1963
Hi how do I get my pin number
I've forgotten my pin number
Please see @oldfella 's response above your post
When setting up a account with sky the pin is ushaly set up at same time and should be the last 4 digits of your phone number unless changed since
This message was authored by: Invisiblename
You do realise that you are responding to a 3 month old post?
I am just another Sky customer!
Yes but likely someone else will come through with same problem and find my comment helpful I been trying to fined mine and reading comments with no luck until found out and remembered setting it up so hopefully helpful to someone else in future
OK, but the default PIN number is the last 4 digit on your viewing card, not your phone number.
That's good for those who have cards I have the sky puck which don't have a card and is pin is last 4 digits of your phone number so I guess different if you have a viewing card
@Anonymous the difference is you have Sky Stream which has no viewing card,  this is the forum for Sky Q and Sky Q boxes  do have  a viewing card
LG 49SJ 810 V UHD TV
Google Pixel 10 Pro XL mobile
@Anonymous
You've posted on a thread in the Sky Q board so it will be the viewing card solution as described by @Invisiblename and therefore your puck isn't relevant.
As you've posted in the wrong forum, all you're doing is potentially confusing Sky Q users
This message was authored by: LeonePeposhi
Just started to open my new sky tv end is asking me for pin to enter how I can get the pin to start my tv
hi @LeonePeposhi
Do you have a SKY Glass TV  or a SKY Q box ?
Answered - Go to Answer
