Discussion topic: How do I get a replacement Mini box?
This message was authored by: Gemlou1
Evening!
I'm so fed up with having to reboot my Mini box every time I use it - how do I get a replacement? (After all, I'm effectively renting it and it's not fit for purpose!)
TIA!
Re: How do I get a replacement Mini box?
@Gemlou1 wrote:
Evening!
TIA!
@Gemlou1 when your mini box isn't working are you rebooting just the mini box ? if so Have you tried rebooting your main Q box first ie
then reboot your mini box
LG 49SJ 810 V UHD TV
Google Pixel 10 Pro XL mobile
Avatar for Gemlou1
I've tried rebooting Sky Q box, reset mini box from factory settings, Sky engineer moved it (when he came to fix broadband).... still doing the same thing. I just want a new box!!
Hi @Gemlou1
First make sure that all Q boxes are on the same Software version and the same standby setting.
https://www.sky.com/help/articles/sky-software-updates.
https://www.sky.com/help/articles/updating-sky-box-software.
https://www.sky.com/help/articles/using-the-standby-settings.
Then try rebooting the main Q box and then when this is completely back up and running reboot the mini.
Reboot the mini as above.
