1
This discussion topic has been answered Discussion topic: Connection between mini and sky Q box is poor
This message was authored by: MattCastle
The connection between my sky Q and mini boxes is poor. This means TV is lagging on the mini and cannot reliably stream. The main Q box and router im are on the middle floor and the mini is on the ground floor. Do I need a booster? If so, which one? Thanks
Re: Connection between mini and sky Q box is poor
Hi @MattCastle
Reboot the mini as above.
Hi @MattCastle
