Discussion topic: Hi, so I am paying just under £70 for nothing
Message posted on 19 Nov 2023 09:43 AM
I'm paying just under £70 just to watch Netflix and Amazon Prime and my sky remote doesn't work.
Message posted on 19 Nov 2023 09:57 AM
Re: Hi, so I am paying just under £70 for nothing
@Charlie37 wrote:I'm paying just under £70 just to watch Netflix and Amazon Prime
That's not nothing? It's not clear what your issue is?
https://www.sky.com/help/articles/sky-q-remote-help
Message posted on 19 Nov 2023 10:02 AM
You will have access to the Sky Entertainment channels as well as Netflix and Amazon so not sure why you are paying £70 for nothing as clearly that isn't the case.
Message posted on 19 Nov 2023 10:04 AM
What have you done about it!
Message posted on 19 Nov 2023 10:08 AM
My remote does not work and my recordings and anything on sky won't work nothing works other than my apps so I feel like I'm paying more than I should be
Message posted on 19 Nov 2023 10:09 AM
Have you tried rebooting your main Sky Q box?
~ after 30 seconds switch the box back on
~ press the 🏠 button
