Discussion topic: Hi my sky Q box is not connecting to the internet. This is having a knock on with my multi room boxe
Message posted on 08 Jan 2024 10:30 AM
My sky Q box is not connecting to the Internet. This is having a knock on with my two multi room boxes. I have taken the ethernet cable out of my Q box and tried it on my laptop and my laptop connects
Message posted on 08 Jan 2024 10:49 AM
Re: Hi my sky Q box is not connecting to the internet. This is having a knock on with my multi room
Have you carried ou a Network reset on the main Q box with the Ethernet cable connected
Highlight Status and then select Reset on the right hand side. Follow instructions to connect wired to your router.
