Discussion topic: Hi Sense Tv overrides Sky Q
This message was authored by: homerhiggins
For the last 2 years when I switch on my HiSense TV it defaults to Sky Q which I control with my Sky handset. Now when I switch on the Tv it defaults to the HiSense Invidia Home Screen and I have to use the TV remote to switch back to Sky Q. Can I reset this back to how it was please?
Andy
Re: Hi Sense Tv overrides Sky Q
If HDMI control is enabled use the Sky (or home) button on your Sky remote.  If the TV is in standby it should turn on and select Q as input.
Avatar for homerhiggins
Thanks but I've tried that and after coming out of standby the tv only responds to the TV remote initially.
Have you tried re-pairing your remote to the TV?
Press 7 and 9 together for a few seconds until the light flashes, then hold 1 and 3 for three seconds and follow the on-screen instructions
Unfortunately that doesn't work either! Thanks for trying.
It may be something that's changed on your TV.  Perhaps a firmware update or settings?
I even reset the tv to its original settings but still does the same🙈
