4
This discussion topic has been answered Discussion topic: Hard disc faulty
This message was authored by: RW09
Hard disc faulty
Hard disc faulty, have had to complete two hard resets in past 5 days replace with new Sky Q box
This message was authored by: lettice Answer
Re: Hard disc faulty
If you have tried all mentioned in the Sky article below for recording and hard drive issues, you can order a replacement Sky Q box online from the link in the help article;
https://www.sky.com/help/home/sky-tv/sky-tv-q/fixing-sky-q/fixing-recordings-and-downloads/fix-a-pro...
Make sure when you handover your faulty Sky Q box to the courier with the replacement that you remove your Sky viewing card from your faulty box.
You will need this to place in your replacement box.
Avatar for RW09
Two hard disc resets in past 5 days. Will Sky repalce this sky Q box with new FOC?
Avatar for RW09
@lettice , thanks. I followed the link and clicked on order new sky Q box but I don't see it entered on track my orders. I assume it takes some time to be added?
Avatar for RW09
Called Sky, Sky Q box requires to be replaced due to failing hard disc issue.
