42
This discussion topic has been answered Discussion topic: HDR indicator no longer showing
This message was authored by: hapazard2
Hi
Have UHD subscription and watching footie on 401. I used to check HDR working by going into Bravia picture settings-this would then show on TV briefly.
I've tied now, but screen just shows "HDMI4". (Slot connected to Sky Q)
The only recent change has been the addition of Sonos Arc. That can't have affected picture quality, can it?
Think I'm going senile
Avatar for hapazard2
Level 5 icon
This message was authored by: hapazard2 Answer
Re: HDR indicator no longer showing
Omitted to sayI was able to set 10 bit resolution after reset of Q box.
@hapazard2 wrote:
Hi
Hi @hapazard2
Join the club.
Are you still set to 2160P -10bit resolution on your Q box
Level 5 icon
Hi
Yep. Thanks.
I've also looked at the list of Sky UHD/HDR content, and that's not showing when I try that?
How bizarre.
@hapazard2 wrote:
Hi
Yep. Thanks.
How bizarre.
Where are you looking at UHD/HDR content @hapazard2
@hapazard2 wrote:
https://www.pocket-lint.com/tv/news/sky/153328-sky-q-4k-hdr-all-the-shows-currently-available-in-hdr...
Yeah - that's nearly 3 years out of date @hapazard2
A Man Called Otto is currently the latest Sky Cinema in HDR
Home menu - todays top pick.
Try rebooting your TV and Q box
To reboot your box press Standby on your Sky Q remote (if the box responds to the remote), and then switch off and unplug at the mains.
To reboot TV disconnect power for 30 and then reconnect  or maybe your Sony reboots if you hold Standby off for more than 3 secs
Level 5 icon
Cheers. I thought (wrongly?) all the footie on 401 was HDR.
hi @hapazard2
401 should be in HDR if you have UHD  & as you hope HDR working correctly.
401 is SKY Sports Main Event UHD but is 'Smart Swapped' depending your subscription - check that it is showing as SKY SpMEUHD and not just HD
Hopefully the power down restart that @oldfella suggested will sort you
Currently is @hapazard2  if it's UHD
Level 5 icon
Thanks. Definitely says UHD next to 401. Something weird happening, unless Sky suddenly started charging for HDR.
Can I suggest you try changing the box resolution to HD -& then fully exit & then go back & reset back to 2160p 10 bit (maybe even do a complete power down of the TV in between)
Level 5 icon
Or Sky are penalising people with sound bars.
Hi @hapazard2
My Sony has no HDR indicator .
I need to use the TV remote  Info button to establish UHD/HDR - Audio input. If I'm not using my amp
@hapazard2 wrote:
Hi
Just a thought - after adding the Sound bar did you change the HDMI port on your TV ?
If so double check all the settings on your TV for the new port
Is your Soundbar HDR (HLG version)  compatible @hapazard2?
