Discussion topic: Netflix Error Code tvq-pb-101 (5.6.1)
This message was authored by: united2468
I'm trying to watch Netflix on my Sky Qnbox and keep getting the errorncode tvq-pb-101(5.6.1).
I have reser the apps, reset the box by powering it down but nothing has worked!
Any suggestions?
Re: Netflix Error Code tvq-pb-101 (5.6.1)
Any suggestions?
Hi @united2468
With Settings highlighted press 0 0 1 Select
