Discussion topic: HDR Netflix
This message was authored by: andy3434
HDR Netflix
I cannot watch anything on Netflix in HDR. It's constantly freezing. Any idea how to fix this issue
Re: HDR Netflix
The box freezes? Can you exit the app when this happens?
Avatar for andy3434
Re: HDR Netflix
Yes i have to keep pressing start again for it to carry on. It seems like the speed of the internet is the issue.
But a speed test shows 150 meg  so I don't think it's this.
Re: HDR Netflix
Netflix app speedtest?
Avatar for andy3434
Re: HDR Netflix
For some reason it's only showing 55.92 Mbs
Re: HDR Netflix
Should be plenty
Box is set to 2160p / 10bit, presumably?
Avatar for andy3434
Re: HDR Netflix
  • Yes so I wonder why
Re: HDR Netflix
Maybe try an app refresh in the installer menu
what version of box is it?
Avatar for andy3434
Re: HDR Netflix
Not sure to be honest.
Re: HDR Netflix
They all look the same except the v1 2TB had a silver edging (and didn't do HDR) so it's not one of those.. It tells you in the system info in the menu.
v2 has an external power brick. V3 does not.
