Discussion topic: Programme not let loading
This message was authored by: Ween69
Tv downstairs works fine.. but my bedroom is absolutely rubbish and always has been but I'm paying for a service I don't use I need help
This message was authored by: Adam+sky+82
Re: Programme not let loading
Hi, You would need to contact Sky to remove the multiscreen subscription
@Ween69
Presumably the Sky Q box upstairs is the mini box? Have you rebooted the boxes?
Try a reboot of the main Sky Q box, then once that’s back up and running do the same with any mini boxes if applicable -
~ press the 🏠 button
Allow 5-10 minutes before things hopefully revert back to normal.
