Discussion topic: Gaming pc interferes with sky
Message posted on 06 May 2026 10:48 PM
Every time my son uses his gaming pc our main sky q box and the 5 minis we have, all freeze. Thought about switching to Puks but doesn't sound like it will resolve it. Pc is wired direct to router and router is newly swapped to a WiFi 7. Fibre broadband speeds are great and we have WiFi boosters also. How can this be resolved?
Message posted on 07 May 2026 06:27 AM
Re: Gaming pc interferes with sky
Can you put the PC on a separate vlam on the router?
This is the first tike I've heard of anything like this. Usually the Q spams the network and causes problems for other devices.
Message posted on 07 May 2026 07:22 AM
@Andy528 wrote:Every time my son uses his gaming pc our main sky q box and the 5 minis we have, all freeze. Thought about switching to Puks but doesn't sound like it will resolve it. Pc is wired direct to router and router is newly swapped to a WiFi 7. Fibre broadband speeds are great and we have WiFi boosters also. How can this be resolved?
Are you saying it's a 3rd party router you're using? What make & model?
Not a Sky employee
Sky FTTP 500Mb to Max Hub (WiFi disabled)
Pair of TP-Link Deco BE65's in AP mode used for WiFi access, main Deco hardwired to Max hub
Message posted on 07 May 2026 09:27 AM
The pc line hose into the blue lan 2.5g on the back of the router. The wan 2.5g red goes to the wall unit, so this is separate isn't it?
Message posted on 07 May 2026 09:30 AM
It's a Brsk better WiFi 7 router
Message posted on 07 May 2026 09:41 AM
@Andy528 wrote:It's a Brsk better WiFi 7 router
Is this with Youfibre broadband?
Not a Sky employee
Message posted on 07 May 2026 11:15 AM
Yes it was Brsk but they were bought out by You Fibre
