15
This discussion topic has been answered Discussion topic: GB New not able to pause or rewind
This message was authored by: ExiledGeordie
Suddenly not able to Pause or rewind GB News. Getting message saying not possible. WHY  ? 9/11/25
This message was authored by: MightyQuinn Answer
Re: GB New not able to pause or rewind
This message was authored by: SueEO
It's been like this for two days for me.  Also the same on CNN when checking other news channels.  Hope it's fixed soon!
Hi @SueEO  @ExiledGeordie   I would report it to viewer relations viewerR@sky.uk
This message was authored by: Canary1953
I have the same issue and have just reported it to viewer relations and I suggested that it is the Sky Ad Smart system that is corrupt and needs fixing
Thank you.  I've had a reply and they hope to have it resolved soon. 🤞🏻
This message was authored by: den+w
Re: Pause / rewind issue 16/09/25
Had same problem for last couple of days, but it seems only with gbnews. Done the recommended fixes but still same. Infuriating.
@den+w
I have moved your post into a thread discussing the issue with GB News.
Avatar for ExiledGeordie
Thank to all that have replied. Does SKY have it in for GBNEWS  ?.
No, Sky actually handle the advertising on GB News so it's not in their interest to harm it in any way.
https://www.skymedia.co.uk/channels/gbnews/
This message was authored by: paulinebatey
Can’t rewind or pause GB news
Sky please look at why GB news can't pause or rewind  other channels work fine
Re: Can’t rewind or pause GB news
hi @paulinebatey
As you will see I have moved your post onto a discussion covering this issue
This message was authored by: SuJay
I have the same issue.  Will they publish the fix
This message was authored by: Jenny+wwh
Have the same issue here - again - after a few weeks of working normally. Last couple of days Pause/rewing on GBN fails with message.
This mornining Monday 10th Nov. Other BBC channels and CNN, alliJ etc working fine then went back to GBN 512 and now thats pausing/rewinding normally.
Very strange reoccuring fault..
This message was authored by: M100pgc
GB news channel only - unable to pause or rewind live
In the last week have found that if I select GB news channel, my Q box will not let me pause or rewind the live feed.
Some times it suddenly starts to work again and then is fine until I change channel, when I return the fault is back.
I have tried many other channels and every thing is working fine.
If I record the GB news channel and playback it in real time it will work fine but is a very messey solution.
Any ideas?
Why has this been marked as ANSWER?
