2
This discussion topic has been answered Discussion topic: My sky q is stuck on 1 channel cant use remote to go down channel no sound nothing
This message was authored by: KATHLEEN42
My sky is stuck on one channel can't use remote no sound either and remote won't move channels
This message was authored by: Laing1 Answer
Re: My sky q is stuck on 1 channel cant use remote to go down channel no sound nothing
@KATHLEEN42 Have you tried rebooting your main Q box ie
If the remote still doesnt work
Try resetting your remote.
Press the buttons 7 & 9 together on the remote until it’s led flashes four times.
Then press 1 & 3 together until the led flashes twice then follow onscreen instructions to repair the remote.
LG 49SJ 810 V UHD TV
Google Pixel 10 Pro XL mobile
Avatar for KATHLEEN42
I rebooted it and it's fine now thanks
