Discussion topic: Freesat not finding signal
Message posted on 10 Dec 2023 03:37 PM
We have Sky Q. Bought a Freesat box as we are cancelling SKY
The internet on the box has connected fine but no satellite signal. Tried leaving it switched on and then leaving it overnight on standby. Still no signal.
Any advice what to do with this please ?
Message posted on 10 Dec 2023 03:42 PM - last edited: 10 Dec 2023 03:45 PM
Re: Freesat not finding signal
Is it a 4K freesat box ?
The non 4K freesat boxes need a different LNB (the electronic bit on the dish) to SKY Q - although the 4K freesat boxes should be able to use it
Edit - if it is a 4K Freesat box then please see this post with some advice:
Message posted on 10 Dec 2023 03:58 PM
It is a 4 k recordable box. Tried all the steps in the other thread to no avail 😔
Message posted on 11 Dec 2023 06:32 PM
when does your sky sub end? have a try when the sky signal is switched off as that could be the reason.
Message posted on 11 Dec 2023 06:34 PM - last edited: 11 Dec 2023 06:36 PM
I am sorry but a SKY Subscription has no bearing on Freesat channel reception via a Freesat box
Message posted on 11 Dec 2023 06:56 PM
Could Sky be blocking the signal ?
Message posted on 11 Dec 2023 06:57 PM
No
Message posted on 11 Dec 2023 06:59 PM
@elderwandninja wrote:Could Sky be blocking the signal ?
No
Have you tried contacting freesat customer support on 0 3 4 5 3 1 3 0 0 5 1
Godfrey.
Message posted on 11 Dec 2023 07:21 PM
Been on live chat with Freesat trying to find a solution but still doesn't work
Message posted on 11 Dec 2023 08:21 PM
@elderwandninja Does your Sky Q receiver still work correctly when you connect the satellite dish coaxial cables back into it?
Do you have your own Sky satellite dish, or are you using a communal Integrated Reception System installation?
Godfrey.
Message posted on 11 Dec 2023 08:30 PM
It's our own Sky dish. Private house. Sky Q box works
Message posted on 11 Dec 2023 08:57 PM
@elderwandninja What happens if you try doing a channel scan by going to Settings, then Freesat Channels and then Channel Scan.
This should indicate what type of LNB is connected and then search for a Freesat satellite transponder signal.
Godfrey.
Message posted on 11 Dec 2023 09:06 PM
Signal Test
No signal
On the top in small text it says a change in cables was detected
Message posted on 12 Dec 2023 07:47 PM
The LNB needed to be changed to a UNIVERSAL one. So had to pay a satellite engineer to swop it
Hope this helps anyone else who is moving from Sky Q to Freesat
Message posted on 12 Dec 2023 08:11 PM
@elderwandninja wrote:It is a 4 k recordable box. Tried all the steps in the other thread to no avail 😔
Do you know the brand? Arris should work with the same LNB as SkyQ, others not.
Sky Q 2TB box and one Minibox
