Discussion topic: Sky box keeps returning to home screen when watching a recording
This message was authored by: Juliaporto
My Sky box keeps returning to the home screen when I'm watching a recording. It's not the main box, it's the associated one.
Re: Sky box keeps returning to home screen when watching a recording
@Juliaporto
Try a reboot of the main Sky Q box, then once that’s back up and running do the same with any mini boxes if necessary-
~ press the 🏠 button
▪️I AM NOT A SKY EMPLOYEE ▪️
Avatar for Juliaporto
Just tried that and it didn't work unfortunately, within five mins of playing a recording, it boots back out to the home screen
Hi @Juliaporto
I'll.try this, thank you
